2948 Switch IOS Upgrade.
Apr 10th, 2008
I have a 2948 switch with an IOS that i am fing it difficult to use,most commands are not the conventional ones,Could any of you give some guidance on how i can do this upgrade?
glen.grant Thu, 04/10/2008 - 03:27
  • Purple, 4500 points or more
If it is a 2948G then it is catos only and "cannot" be upgraded to IOS. You will have to learn how to use catos if you want to use this switch still, it is EOL at this point.
Jon Marshall Thu, 04/10/2008 - 03:41
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Is there anything in particular you are having problems with ?
