ACS Database Replication between SE and Windows
Apr 10th, 2008
I currently have 2 Windows ACS servers (4.0.1.27) in production and replicating databases. I also have a solution engine (appliance) running 4.1.4.13.7. I plan to upgrade the Windows ACS servers to 4.1.4.13.7 (same as the SE). I know that the software versions have to match for replication to work. Recently, I received conflicting information about database replication. I was told that a ACS SE (solution engine 1113) can not replicate to a Windows ACS server, even if the software versions match. Before I change my production environment, I thought would seek out additional input.
rmeans Thu, 04/10/2008 - 07:11
My conflicting source changed their position. Replication will work.
