Verify Subnet zero
Answered Question
Apr 10th, 2008
Hi. I just need to clarify if ip subnetzero is enabled, does that mean i can use subnetworks as ip addresses like 192.168.0.0 for example?
Thanks in advance.
Correct Answer by Jon Marshall about 8 years 11 months ago
No that's not what ip subnet-ero means.
192.168.0.0 255.255.255.0 = subnet 192.168.0
You can use this subnet but 192.168.0.0 is not an address, it is a subnet number so the first address would be
192.168.0.1 255.255.255.0
You generally wouldn't want to allocate another IP out of the same subnet to another interface on the same router - with ethernet it will not let you, with serial i seem to remember reading on this forum that the router will let you do this but not sure why you would want to.
Jon
Overall Rating: 5 (1 ratings)
Jon Marshall Thu, 04/10/2008 - 03:55
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Assuming 192.168.0.0/24 yes it does mean that.
Jon
marcusbrutus Thu, 04/10/2008 - 04:02
Just to clarify, does that mean that i can assign an ip add of 192.168.0.0/24 on one serial int and 192.168.0.1/24 on another attached serial interface within the same subnet which is 192.168.0.0/24?
Correct Answer
Jon Marshall Thu, 04/10/2008 - 04:19
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jon
Hi Marcus
No, I don't think a router will not allow you to configure two separate interfaces with IP addresses from the same subnet or over lapping subnets (i.e. 192.168.0.1/16 and 192.168.1.1/24) for that matter.
***Edit*** This statement is not strictly correct, as a router will allow you to configure IP addresses from the same subnet on Serial interfaces. The above statement only applies to Ethernet interfaces. Thanks Jon *** End of Edit ***
Also having "ip subnet zero" enabled has nothing to do with configuring a subnet number on an interface. Whether "ip subnet zero" is enabled or not it is considered bad design practice to assign either the network/subnet number or the broadcast IP address to any interface, whether the equipment will accept this configuration or not.
The algorithm for working out the usable host IP addrsses on a subnet is (h^2)-2, where "h" equals the number of host bits (contiguous "0's") in the subnet mask, reading in binary from right to left. On a /24 subnet this figure is 254 or (8^2) = 256 -2 = 254.
Enabling "ip subnet zero" allows the use of the first and last subnets when subnetting a major network.
E.g
If you had the major network 152.16.0.0/16 and you want to subnet it using a /24 bit mask.
With "ip subnet zero" enabled the algorithm to work out the number of subnets is n^2, where "n" is equal to the number of host bits borrowed. 8^2=256, so you have 256 usable subnets.
With "ip subnet zero" disabled, the algorithm is (n^2)-2, where "n" is equal to the number of hosts bits borrowed. (8^2) = 256 -2 = 254, so you can only use 254 subnets.
Best Regards,
Michael
marcusbrutus Thu, 04/10/2008 - 04:20
Jon, sorry to disturb you again. I got a bit confused on the subnet issue. Given an ip of 192.168.0.0/24, the total no. of subnets according to the formula is 254 right? But the actual subnet range would be from 192.168.0.0/24 to 192.168.254.0/24 isn't it?
Then the total would be 255. Is this right?
Jon Marshall Thu, 04/10/2008 - 04:26
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
No problem.
192.168.0.0/24 = 192.168.0.0 255.255.255.0 = 1 subnet with 254 possible host addresses
Where your confusion comes from is the subnet mask ie. /24.
192.168.0.0/16 = 192.168.0.0 255.255.0.0 is what you are thinking of.
Jon
marcusbrutus Thu, 04/10/2008 - 04:34
But considering that i intend to use 192.168.0.0/24, the subnet range would be 192.168.0.0/24 till 192.168.254.0 right? Which is a total of 255 subnets?
Jon Marshall Thu, 04/10/2008 - 04:36
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Okay i see the confusion. Yes your subnets would be
192.168.0.0/24
192.168.1.0/24
192.168.2.0/24
which is summarisable as 192.168.0.0/16.
Does this make sense ?
Jon
marcusbrutus Thu, 04/10/2008 - 05:00
Thanks for your patience Jon. I guess i was referring to your previous statement where you said:
Considering that i intend to use 192.168.0.0/24, does that mean that aside from being able to use 192.168.0.0/24 as a subnet, i can also use 192.168.255.0/24 as a subnet? If this is the case, the broadcast address of subnet 192.168.255.0/24 is 192.168.255.255 right? I think i get it now.
