No Codec
Apr 10th, 2008
Hi there,
I'm having same problem as somebody described at
http://puck.nether.net/pipermail/cisco-voip/2005-March/003376.html.
I have Cisco 5350XM and am trying to run TCL IVR v2.0 script
app_debitcard.tcl
Basically the error is:
Apr 9 07:50:43.987: //55274//MSM :/ms_asDone_buginf: Stream Association
Failed: Requested codec=0x5=g711ulaw, Negotiated codec=0xFFFFFFFF=No Codec
It happens when first media play function plays the au file and after
going to next function second media play runs, but this error appears
and voice/audio is not heard.
I appreciate if somebody can help me in this regard.
thanks,
aghaznavi Wed, 04/16/2008 - 07:39
  • Silver, 250 points or more
It may be the dial peer fails or check that the media resource group/list for the gateway has the transcoders defined.
