Call Forward from 0 to different numbers
I need to find a way to enable callers to 0 out of the Greeting message and then have a number called, then if that number does not pickup the next number is called and so forth until we are at the end of an escalation list.
I can 0 out and send to one number but then that numbers line settings takes over.
Any ideas?
Overall Rating: 5 (1 ratings)
Jaime Valencia Thu, 04/10/2008 - 09:04
  • Cisco Employee,
  • Hall of Fame,
    2011
have you tried sending the 0-out to a hunt pilot that's associated to a line group of the phones you want to ring??
or to a pilot point if using AC?
javalenc
if this helps, please rate
Jaime Valencia Thu, 04/10/2008 - 11:56
  • Cisco Employee,
  • Hall of Fame,
    2011
reset the hunt list a couple of times, that usually makes it register
javalenc
Rob Huffman Fri, 04/11/2008 - 04:45
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hey Jaime,
Nice thinking on this one :) I was trying to wrap my head around this for a bit and you nailed it! 5 points from this end.
Take care,
Rob
