Turn off/on wlan
Apr 10th, 2008
We are using two WLCs e several LAPs, a WCS and an ACS radius.
The question: it is possible turn off the radio, automatically, and than turn on at determined time?
thanx for you support
Overall Rating: 5 (2 ratings)
Scott Fella Thu, 04/10/2008 - 04:37
The only way you can do this is to run some sort of script. SSH to the WLC and disable the radio on a particular AP. There is no function on the WLC to disable a radio. On ACS, you can set day's and time for a certain user policy, but it will not disable a radio.
ericgarnel Thu, 04/10/2008 - 05:18
Fella5 is correct, scripting is the way to go.
Another alternate is use time-based acls on an upstream device.
You could also look into the option of ethernet controlled power strips for the APs, but it is not very financially feasible. http://www.intelligentpowerstrips.com/
marcellosozzo Fri, 04/11/2008 - 02:19
Tx for replay.
It is possible with some script disable the WLAN instead of the single radio of the APs.
There is a CLI command to change a WLAN status?
Like in the GUI:
Tab: General
field: Status
value: check/uncheck
ericgarnel Fri, 04/11/2008 - 05:27
You could try using and expect/tcl script to do a 'config wlan disable '
I'm not sure if a standard script would barf on the user login/password delay, but it is worth trying.
Also, I keep hearing rumours of an IOS like CLI for the controllers in an upcoming release, if that is the case, then scripting will be super easy.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
