HSRP_not working
Answered Question
I have four Cisco 1800 series routers and a 3750 switch. All the four routers are connected to the 3750 switch.
The first router is used for Mail traffic
The second for Citrix traffic
the third for general web browsing
The fourth router is a backup link.
I have configured HSRP on the routers and policy routing on the cisco switch.
The internet connection of router R1 went down this morning and the bacup failed to kick in.
The attached file contain the Configuration of the routers and a switch.
I would be very grateful if somebody could checked the config and help me troubleshooting this problem.
Kind regards,
Tarek
Correct Answer by lamav about 8 years 11 months ago
Hi:
I imagine that the mail clients sit behind the 3750, which will then forward the traffic to the correct next hop.
Therefore, the problem is with the static route on the 3750 switch for the mail service.
ip route 195.x.x.Z 255.255.255.255 132.147.12.5 (MAIL Server)
The static route should be pointing to the HSRP VIP for group 2, which is 132.147.12.17, not the vlan interface for R1. Otherwise, you are always going to be forwarding traffic to one physical router, instead of the virtual gateway address, which each standby physical router can take ownership of when it becomes necessary, such as when the HSRP primary router fails or, as in your case, its serial link fails.
Victor
Overall Rating: 5 (1 ratings)
smothuku Thu, 04/10/2008 - 05:02
  • Silver, 250 points or more
Hi ,
Configure " standby track "
Under Vlan 1 of every router exceprt R3 and check the issue.
Satish
sorry for the delay, I have the added the following command line to interface vlan 1
R1.
standby 2 track atm0
R2.
standby 1 track atm0
R4.
after I disconected the internet connection on R1 and issue sh standby on the stadby router. the standby router state change to active state.
but when i tried to access the mail it failed so I issued tracert on the local pc
tracert 195.x.x.x. (mail server)
it is still taking the route 132.147.12.5 (primary vlan 1 int) instead of 132.147.12.8
can somebody help me fix this problem.
thanks
Tarek
Correct Answer
lamav Fri, 04/11/2008 - 09:01
  • Blue, 1500 points or more
Hi:
Victor
mattcalderon Fri, 04/11/2008 - 09:42
You probably need to verify that your default gateway on the pc is the HSRP virtual address.
