iSCSI question
Apr 10th, 2008
I have a question about iSCSI & HBAs...
1) an HBA is a nic that uses its own processing power and doesn't use the PC processing power?
2) not sure whether iSCSI uses an HBA or regular nic, can it be used with or without an HBA?
Thanks!
LisaG
Overall Rating: 5 (1 ratings)
inch Fri, 04/11/2008 - 21:54
  • Bronze, 100 points or more
Hi Lisa,
iSCSI can be done in both software (ie: cisco iscsi driver, microsoft iscsi driver etc) or done at a hardware level where you purchase a card which usually has a TCP offload engine (ToE) and offloads the iscsi component as well.
So in short, you can get a iscsi HBA or you can use a software solution.
Cheers
Andrew
Trending Topics: Storage Networking
