CUE GUI adding hunt group members not working
Apr 10th, 2008
  • Silver, 250 points or more
When we use the CUE GUI (version 3.1.2, and in version 2.10 - old version we had before upgrading) when you go under System Parameters , and Hunt Group. I am able to delete members added through the router CLI but using the GUI after you add members to the hunt group and hit the button to save the changes, it just sits there and does not update.
I can change other settings through the CUE GUI fine and delete hunt group members through the GUI.
The IOS version is 12.4(19) now with the matching CME-GUI files on the flash. Before we had 12.3(14)T2 with the appropiate CME GUI files on flash with same problem.
Anyone have an idea? Thanks
