PIX Site to Site VPN Issue
Apr 10th, 2008
Consider the following Phase 2 parameters of a VPN .The issue is i need to give clear text access-list too along with the normal Crypto ACL and NONAT ACL .Iam not able to find out the reason for the same
crypto map outside_map 140 match address outside_cryptomap_140
crypto map outside_map 140 set peer 65.127.X.X
crypto map outside_map 140 set transform-set ESP-3DES-SHA
a)Crytpo ACL
access-list outside_cryptomap_140 extended permit icmp host 10.10.49.30 host 10.200.253.8
access-list outside_cryptomap_140 extended permit ip host 10.81.34.59 host 10.100.8.3
access-list outside_cryptomap_140 extended permit ip host 10.10.49.30 10.100.8.0 255.255.255.0
b)NO NAT ACL
access-list webdmz_outbound_nat0_acl extended permit ip host 10.10.49.30 host 10.200.253.8
access-list webdmz_outbound_nat0_acl extended permit ip host 10.10.49.30 10.100.8.0 255.255.255.0
access-list appdmz_outbound_nat0_acl extended permit ip host 10.81.34.59 host 10.100.8.3
c)Clear text ACL
access-list webdmz_access_in extended permit tcp host 10.10.49.30 10.100.8.0 255.255.255.0 eq ssh
access-list webdmz_access_in extended permit icmp host 10.10.49.30 host 10.200.253.8
access-list appdmz_access_in extended permit ip host 10.81.34.59 host 10.100.8.3
Query : In a Site to Site VPN ideally only Crypto ACL (Interesting traffic ACL ) and NO NAT ACL is required . However in some of the VPN Scenarios Clear text ACL is also required without which even after the tunnel is up , devices are unreachable and it will give a following error .
“Connection denied by webdmz_access_in”
Please let me know the following
1)Is it really required
2)If not , what are those scenarios in which it needs to be given
Ankur
husycisco Thu, 04/10/2008 - 06:45
Hi Ankur,
As you know, traffic from a higher security interface to a lower security interface is permit by default. That means if there is no access-list applied to the higher security leved interface, traffic will be permit. It is not really required.
But in some firewall implementations, security admins apply access-list to that higher security leveled interface to filter traffic originated from inside, the trusted users. In this case, they permit specific traffic, then a deny any any in the end. Since the traffic is filtered, you have to specifically permit the tunnel traffic.
