04-10-2008 07:02 AM - edited 03-03-2019 09:30 PM
What is the explanation of the option " match-in-vrf" in the command ip nat inside source?
Because nothing is explain on the CCO.
router(config)#ip nat inside source list TEST pool POOL_TEST vrf VRF_TEST ?
match-in-vrf Match incoming vrf
overload Overload an address translation
<cr>
04-17-2008 06:10 AM
The match-in-vrf keyword is missing from the ip nat inside source command, and the ip nat inside source command is not accepted at all in interface-configuration mode. This symptom is observed on a Cisco 7200 series that runs Cisco IOS interim Release 12.4(11.6a) or interim Release 12.4(12.03)T but may also affect other routers.
10-07-2010 11:26 PM
the match in vrf allow you to have the same translation in two distinct vrf
so that you can have something like
ip nat inside source a.a.a.a b.b.b.b vrf a match-in-vrf
ip nat inside source a.a.a.a b.b.b.b vrf b match-in-vrf
but this feature is, as far as I know, only working for a vrf-lite config.
07-15-2013 05:55 AM
There is a new CCO doc explaining match-in-vrf -
http://www.cisco.com/en/US/docs/ios-xml/ios/ipaddr_nat/configuration/xe-2/iadnat-match-vrf.html
07-02-2021 08:27 AM
The Match-in-VRF Support for NAT feature supports Network Address Translation (NAT) of packets that communicate between two hosts within the same VPN routing and forwarding (VRF) instance. In intra-VPN NAT, both the local and global address spaces for end hosts are isolated to their respective VPNs, and as a result, the translated addresses for the hosts overlap each other. The Match-in-VRF Support for NAT feature helps separate the address space for translated addresses among VPNs.
In summary:
! The match-in-vrf keyword enables NAT inside and outside traffic in the same VRF.
! The match-in-VRF Support for NAT feature helps separate the address space for translated addresses among VPNs.
