Static route help
Apr 10th, 2008
I have a VPn on my Cisco ASA firewall. I used the VPN wizard to create it, but it didn't work until I added a static route to the ASA.
Remote network is 172.16.1.0/24
I added:
route outside 172.19.15.0 255.255.255.0 Internet_Router 1
Which worked, but I also removed this and added:
route outside 172.19.15.0 255.255.255.0 1.2.3.4 1
Now 1.2.3.4 is the peer address of the remote router, which one is best to use? point to our internet router to find the remote network or point that traffic straight to the remote router for the VPN?
fortis123 Thu, 04/10/2008 - 09:02
is the preferred one. As it is direct next hop to ASA.
hth
thank you
MS
Rick Morris Thu, 04/10/2008 - 12:30
  • Silver, 250 points or more
In static routing you point your traffic to the next hop IP, or on the router it can be the outbound interface.
