Need Remote access for support
srue Thu, 04/10/2008 - 09:36
make sure the inside IP address of the appliance is part of the crypto ACL. make sure the 'management-access inside' command is configured as well.
then make sure you've configured telnet and http access to the device from the address pool used for remote vpn access.
bauti1428 Fri, 04/11/2008 - 08:29
Go to configuration -> Device Management -> ASDM/HTTPS -> Add the IP address of the host ip that is going to get in to your box. Specify the interface in this case if they are outside your network, it will be the outside interface.
Same thing you have to do for SSH and telnet but I don't recommend using telnet since it sends data in clear text.
