Cannot ping router
Apr 10th, 2008
router1>sh ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 10.20.0.165 to network 0.0.0.0
S 172.16.0.0/16 [1/0] via 10.20.0.58
67.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 67.151.48.156/30 is directly connected, Multilink1
C 67.151.48.157/32 is directly connected, Multilink1
10.0.0.0/16 is subnetted, 6 subnets
C 10.20.0.0 is directly connected, FastEthernet0/0
S 10.40.0.0 is directly connected, Multilink1
S 10.60.0.0 is directly connected, Multilink1
S 10.80.0.0 is directly connected, Multilink1
S 10.100.0.0 is directly connected, Multilink1
S 10.120.0.0 is directly connected, Multilink1
S* 0.0.0.0/0 [1/0] via 10.20.0.165
S 192.168.0.0/16 [1/0] via 10.20.0.58
router1>
router2>sh ip route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
C 67.151.29.157/32 is directly connected, Multilink1
C 67.151.29.156/30 is directly connected, Multilink1
10.0.0.0/16 is subnetted, 1 subnets
C 10.40.0.0 is directly connected, FastEthernet0/0
S* 0.0.0.0/0 is directly connected, Multilink
router2>
Above is the "sh ip route" from two routers. router1(10.20.0.1) can ping router2(10.40.0.1) But router 2 cannot ping router 1 WHY? I have been working on this for 2 days. Can anyone help me....PLEASE
Istvan_Rabai Thu, 04/10/2008 - 09:15
Hi James,
Can you please post the running-configs of the routers here so we can have a closer look at it.
Istvan
Richard Burts Thu, 04/10/2008 - 09:27
James
Clearly R1 has a static route to R2 pointing at the multilink. And R2 does not have a route for 10.20 but has a static default route pointing to the multilink.
One thing that would produce this symptom would be if R2 was configured with no ip classless. Can you confirm whether R2 is configured with no ip classless.
As Istvan requests it would be helpful if you would post the router configs - especially if my guess at classless does not explain the issue.
Rick
Rick Morris Thu, 04/10/2008 - 12:32
R2 does not have a static route it appears
You need some way of directing the traffic.
