Status down
Apr 10th, 2008
HI,
I have installed the WLC 4402 and LWAP 1131G,1242AG etc ,every thing works fine,when I try to fix the AP on the wall with Power Over Injector,The AP get registered but the Radio Link status shows down.
What could be the issue?
Can any one help me?
I have configured teh LEAP authentication for the wireless clients.(I am using Cisco Radius appliance 1.1.1.0 software 4.1 )but i want to configure the EAP authentication,I have no ideas.
can any help me how to configure EAP?
Thanks and Regards,
S.Venkataraman.
Overall Rating: 5 (1 ratings)
Scott Fella Thu, 04/10/2008 - 16:45
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
On the WLC, click on wirless and then click on the AP. Now in the AP, you want to click on Advanced and on the top right you will see Power Over Ethernet Settings. Check both and then on the Power injector selection, choose override.... That always works for me.
Lavanholy Sun, 04/13/2008 - 22:51
thanks a lot,Infact before I get your reply,I have tried that option,it worked,My guess is correct.Thanks a lot.
Thanks and Regards,
S.venkataraman.
Trending Topics - Security & Network
