WAE - Clarification on "wccp tcp-promiscuous" command
Apr 10th, 2008
Hi Sir,
I have a WAE-7326-K9 connected on the same VLAN (VLAN 200) as two Catalyst 6513s. Their configs are as follows:
Core Switch #1
ip wccp version 2
ip wccp 61
ip wccp 62
interface Vlan601
description *** To WAN Access Router Gi0/1 ***
ip address ...
ip wccp 61 redirect out
ip wccp 62 redirect in
interface Vlan200
description *** To WAE ***
ip address 10.200.70.2 255.255.255.240
ip wccp redirect exclude in
standby ip 10.200.70.1
interface Vlan A
description *** Server Farm A ***
interface Vlan B
description *** Server Farm B ***
interface Vlan C
description *** Server Farm C ***
Core Switch #2
ip wccp version 2
ip wccp 61
ip wccp 62
interface Vlan602
description *** To WAN Access Router Gi0/2 ***
ip address ...
interface Vlan200
ip address 10.200.70.3 255.255.255.240
interface Vlan A
interface Vlan B
interface Vlan C
WAE Config
primary-interface GigabitEthernet 1/0
ip address 10.200.70.10 255.255.255.240
exit
interface GigabitEthernet 2/0
exit
ip default-gateway 10.200.70.1
wccp router-list 1 10.200.70.2 10.200.70.3
wccp tcp-promiscuous router-list-num 1 l2-redirect mask-assign
wccp version 2
On the WAE, I configured l2-redirect and mask-assign based on a config example I came across. I don't quite understand the function of these two keywords. Below is the Command Reference for the "wccp tcp-promiscuous" command:
http://www.cisco.com/en/US/partner/docs/app_ntwk_services/waas/waas/v4013/command/reference/glob_cfg.html#wp1151676
Is there anything else I need to configure on the Catalyst switches in order to support the L2 redirection and mask assignment?
Is it best practice to configure these features for a WAE that is directly connected to Catalyst 6500 switches?
Thank you.
B.Rgds,
Lim TS
Zach Seils Fri, 04/11/2008 - 04:18
  • Cisco Employee,
Lim,
The WCCP configuration on the WAE is correct, however on the 6500 you should avoid the use of outbound redirection and the 'ip wccp redirect exclude in' command. Both of these commands cause a portion of the WCCP redirection to happen in software (versus hardware).
Instead of configuring outbound redirection, you can move that service group to the server-facing interfaces as inbound redirection. By only using inbound redirection, you also no longer need the 'redirect exclude in' command.
Zach
