Public hotspot solution
Apr 10th, 2008
Hi all,
I have a 4402 and wcs. I'm working in a project to provide public access to web thought 1242AG AP's. I have just one cable of optic fibre/media converter that i can plug ONE AP on the wired network and use the 4402/wcs to control it.
The question is, can i use this unique wired/highlighted AP to bridge connections from 3 others AP's that i will spread around the park?
Any clues of how to do it?
Rafael
Scott Fella Thu, 04/10/2008 - 16:39
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
From another post, I remember that you can use the 1242 as a mesh ap, but you have to purchase a license for each ap. Then you can run the mesh code on the WLC. I don't know if WCS will really help you so much since ou only have one controller and it is for open guest access. The fibre/media converter can plug into your rap and the other ap's can act as a map.
You might be able to use the 1242 as an LWAP and other aps as a WGB. Might be cheaper.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
