CSS show run - the whole enchilada
Answered Question
Apr 10th, 2008
When I run the "show run" in CSS is stops with ---more - requiring a space to continue. It there a way to tell the CSS to just show the entire config without the pausing?
Correct Answer by ciscocsoc about 9 years 1 month ago
Use the terminal length command.
terminal length takes a value from 2 to 65535. So the command "terminal length 65535" will show the first 65535 lines before prompting for more.
Cathy
Overall Rating: 5 (1 ratings)
Correct Answer
ciscocsoc Thu, 04/10/2008 - 22:40
  • Silver, 250 points or more
Cathy
