Translation of ASA 5510 Commands is it OK
Apr 10th, 2008
I have a Cisco 5510 ASA firewall IOS Version is 8.0.3
The ASDM version is 6.0.3. This firewall will replace a Ciso Pix 506.
I have notice that when I use the command [ tunnel-group JBoy type ipsec-ra]
it gets changed to [ tunnel-group JBoy type remote-access]
Is this what I believe to be a translation of commands ( OK )
THanks
sundar.palaniappan Thu, 04/10/2008 - 19:51
That's corect. Your configuration has created a remote access tunnel group named JBoy. I believe you can use either command and it does the same thing.
Sundar
