How do I enable 2 gigabit interface on ASA5510-sec-bun-k9?
Apr 10th, 2008
hi guys
my ASA5510 has been Security plus licensed, but I cannot find which is gigabit interface. Who can help me enable them, thanks.
ciscoasa# sh version
Cisco Adaptive Security Appliance Software Version 8.0(2)
Device Manager Version 6.0(2)
Compiled on Fri 15-Jun-07 19:29 by builders
System image file is "disk0:/asa802-k8.bin"
Config file at boot was "startup-config"
ciscoasa up 27 mins 10 secs
Hardware: ASA5510, 256 MB RAM, CPU Pentium 4 Celeron 1600 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
Boot microcode : CN1000-MC-BOOT-2.00
SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.01
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.04
0: Ext: Ethernet0/0 : address is 001e.f710.6dd8, irq 9
1: Ext: Ethernet0/1 : address is 001e.f710.6dd9, irq 9
2: Ext: Ethernet0/2 : address is 001e.f710.6dda, irq 9
3: Ext: Ethernet0/3 : address is 001e.f710.6ddb, irq 9
4: Ext: Management0/0 : address is 001e.f710.6ddc, irq 11
5: Int: Not used : irq 11
6: Int: Not used : irq 5
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited
Maximum VLANs : 100
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
VPN Peers : 250
WebVPN Peers : 2
Advanced Endpoint Assessment : Disabled
This platform has an ASA 5510 Security Plus license.
Serial Number: JMX1214L0JQ
Running Activation Key: 0x98015a60 0x3c8f8022 0xd401a5b0 0x80704c60 0x0401b488
Configuration register is 0x1
Configuration has not been modified since last system restart.
ciscoasa#
ciscoasa#
ciscoasa# sh int ip b
Ethernet0/0 unassigned YES unset administratively down down
Ethernet0/1 unassigned YES unset administratively down down
Ethernet0/2 unassigned YES unset administratively down down
Ethernet0/3 1.1.1.2 YES CONFIG up up
Management0/0 192.168.1.1 YES CONFIG down down
ciscoasa#
Overall Rating: 5 (1 ratings)
vitripat Fri, 04/11/2008 - 08:34
  • Gold, 750 points or more
Ethernet0/0 and Ethernet0/1 can be configured as gigabit ports. You can set the speed of these interfaces using the speed command in interface configuration mode.
Please note that interface would still show as "Ethernet0/0" & "Ethernet0/1", but speed can be set to 1000Mbps. This feature was added from 7.2(3) code. Here is a link for the same-
http://www.cisco.com/en/US/docs/security/asa/asa72/release/notes/asarn723.html#wp272663
Hope that helps.
Vibhor.
torex-hiscom Thu, 07/10/2008 - 06:02
Hi Vibhor,
I was trying this too on my 5510 with security plus license, but it doesn't recognize the "speed 1000" command.
I'm running version 8.0.2.
I obtained this hardware in the end of 2005.
Albert Bruggeman
torex-hiscom Thu, 07/10/2008 - 06:16
Oh, I didn't realize that!
I thought 8.0.2 had the features of 7.2.3 but that's not true of course.
Thank you.
