How to Decrease Failover Time
Apr 10th, 2008
Hi Guys!
Is there any way on how to decrease the delay time of a failover line when the other line turns down. Im using EIGRP for load balance and auto-failover.
Istvan_Rabai Thu, 04/10/2008 - 20:34
Hi Chester,
With EIGRP, the failover is very fast, measured in milliseconds, especially when you have a feasible successor route in the topology table (like your situation).
Did you measure the failover time you have now ? What failover time would you like to achieve?
cmadiam82 Thu, 04/10/2008 - 21:51
The time the failover will come is may be around 6seconds. Can you give me a nice way on how to measure it? Im just trying to ping the LAN interface then i will manually shut the other WAN interface from the remote site. H.O site and Remote site are both having to MPLS connection terminated on two Serial Interfaces.
Istvan_Rabai Fri, 04/11/2008 - 06:21
Hi Chester,
Can you please post your running-config and the output of the "show ip route" and "show ip eigrp topology" commands?
I would like to see what you have exactly there.
