MTU Mismatch btw VPN Peers
Apr 10th, 2008
hello ,
We have a VPN btw ASA and Cisco 871 .This ispsec tunnel is up and functional , i can ping the Devices from both sides without any issues , but when we use Xterm or any other chatt protocl we get kiccked off at times , so when i ran a Test tunnel from SDM , i get a report "A ping with data size of this interface MTU size and " Do not fragment" bit set to other end VPN devie is failing , this may happen if there is alesser MTU network which drops the Do not fragment packets " .
My suspicion is branch office router 871 , which has only this tunnel where are main office ASA has 13 more similar tunnels that are fully funtional .
Things that i have tried ,
changing MTU to 1200 on the Fast ethernet of (where tunnel is terminated on 871 router)
TCP-adjust to 1200
When i ping from a desktop that is behind ASA to yahoo.com with -f -l , last respons i get is at 1272. But on similar test from behind 871 goes without any issues uptill 1400 + .
ciscosom Thu, 04/10/2008 - 20:53
partial configuration from 871
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key ****** address x.y.z.w
crypto ipsec transform-set 3des-set esp-3des esp-md5-hmac
crypto ipsec df-bit clear
crypto map vpn 10 ipsec-isakmp
set peer a.b.c.d
set transform-set 3des-set
match address 102
interface FastEthernet3
interface FastEthernet4
ip address x.y.z.x 255.255.255.248
ip access-group 100 in
ip nat outside
ip inspect SDM_MEDIUM out
ip virtual-reassembly
duplex auto
speed auto
crypto map vpn
interface Vlan1
ip address 192.168.5.1 255.255.255.0
ip nat inside
Any help will be greatly appreciated !!!!
