04-10-2008 10:09 PM - edited 03-14-2019 02:04 AM
Hi All,
I have the following setup:
CM 5.1(3)
ICM 7.1(5)
and Outbound Option enabled as well.
I have managed to get the Campaign working for every scenario except if the CPA (Call Progress Analysis) is enabled.
What happen when the CPA is enabled is the call to the customer won't get through. On the gateway i get the following error message:
*Mar 15 05:05:43.215: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x12BA
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x0083, '82002'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '0298881134'
*Mar 15 05:05:43.295: ISDN Se1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x92BA
*Mar 15 05:05:43.319: ISDN Se1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x12BA
Cause i = 0x80AF - Resource unavailable, unspecified
*Mar 15 05:05:43.395: ISDN Se1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x92BA
*Mar 15 05:05:43.399: ISDN Se1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x12BA
Is there any specific configuration for the CPA to work? I've confirm that the silence suppression have been disabled for the Call Manager and Gateway through the CM Service Parameter.
Is there anything else I miss?
Erwin
Solved! Go to Solution.
04-13-2008 11:13 PM
Hi Erwin,
I suggest a new test with the Call Manager logs, try to cross reference this call by this mean:
The error should be reported first in the Jtapi logs(CAUSE_RESOURCES_NOT_AVAIL), there you should see the GUID, cross reference it through the CallManager logs.
90% of times the error is down to CUCM CSS, the dialer needs to be in a G711 region and if you are transferring the call to agents in a G729 region you need MTP resources.
Riccardo
04-11-2008 02:01 AM
Hi Erwin,
those are the requirements:
- MTP Required disabled on CCM gateway config. Only exception is ISN configured as an H.323 GW.
- No VAD on dial peers in voice gateways to disable silence suppression.
Further more could you please confirm you have those values in the registry?
HKEY_LOCAL_MACHINE\SOFTWARE\Cisco Systems, Inc.\ICM\
CPAAnalysisPeriod
2500 ms
CPAMaxTimeAnalysis
3000 ms
CPAMaxTermToneAnalysis
15000 ms
CPAMinSilencePeriod
375 ms
CPAMinimumValidSpeechTime
112 ms
CPANoiseThresholdPeriod
100 ms
CPAMaxNoiseFloor
10000
CPAMinNoiseFloor
1000
CPAActiveThreshold
32 db
CPAJitterBufferDelay
150 ms
Are you doing any codec conversion? Using MTP for that?
If you still get this failure please collect the GW debugs and the following logs and raise a TAC SR with those:
Capture these logs with the trace settings that the Tracing Levels
;http://www.cisco.com/en/US/products/sw/custcosw/ps1844/products_tech_no
te09186a00805b6e23.shtml#trace-lev> te09186a00805b6e23.shtml#trace-lev
Tracing Levels
Note: Make sure you change the trace levels back to the default. If you
do not return the trace levels to the default settings, you can
encounter problems.
* Dialer:
Inc.\ICM\
r\EMSTraceMask=0x000000ff
Systems,Inc.\ICM\
\baDialer\EMSUserData=FF FF
* CTISRVR Registry:
Systems,Inc.\ICM\
tisvr\EMSTraceMask=0xF8
* OPCTest Command:
debug /agent /cstacer /tpmsg /cstaecer /closedcalls/routing
* PIM procmon command:
trace tpcsta* /on csta* /on
In these processes, disable EMSDisplayToScreen in order to minimize the
performance impact during logging. In order to disable
EMSDisplayToScreen, set the value to 0.
* Set the CallManager trace level to detailed for all nodes and capture
log files from all nodes in /program files/Cisco/trace/ccm.
After you enable the trace, use the dumplog utility to capture logs from
the PG for the Dialer, PIM, OPC, and CTI Server. Identify the time stamp
when the test is conducted and the ANI used to make the call.
* Capturing wave files:
1. HKEY_LOCAL_MACHINE\SOFTWARE\Cisco Systems,
Inc.\ICM\
- After you troubleshoot this issue, disable or remove the DWord value
because this DWord value records every call, and no purge mechanism is
available.
*Place a few calls to reproduce the the issue finish, you will find a
series of wavefiles (depending upon the number
of calls you make) under C:\ICM\
organized by port and date/time.
*Gather up all of the logs above and the wav files, zip and attach to the case.
Riccardo
04-13-2008 09:40 PM
Hi Riccardo,
Thank you for your reply.
I have checked your recommendations and it seems that everything has been set correctly apart from the registry values.
I've modified those registry values and restarted the dialer but it still have the same result.
It looks to me that the call to the customer number has failed.
Anyway, I will try to escalate this to Cisco and hopefully we can get this fixed.
Also, I have turned on the Dialer Trace as per your recomendation and got the following result (see attached):
I don't know whether you've seen this before it looks like the error is due to the following:
12:41:30 Trace: <9,0,12:41:20>(CLMGR) Call failed, port: 003, id: 33571861, lc_state: 1 [LCS_INITIATE], cause: 30 [CEC_RESOURCES_NOT_AVAILABLE]
Erwin
04-13-2008 11:13 PM
Hi Erwin,
Riccardo
04-14-2008 02:28 AM
Hi Riccardo,
Thanks again for your help. I will certainly try that tomorrow and see how it goes.
Erwin
04-17-2008 08:30 PM
Hi Riccardo,
I found out that the Dialer ports are in the 'wrong' Device Pool and Location.
I've changed them to be in the right configurations and the CPA is now working! Thank you for your help.
Erwin
