E1 card issue in 3745
Apr 10th, 2008
Hi all,
I had install VWIC-2MFT-G703 E1 card, in 3745 router. In "show diag" I'm seeing that router detected that card, but in "sh running" I'm not seeing that interface. Please help if any configuration required.
Output of Show Diag:
WIC Slot 1:
E1 Drop&Insert & G.703 (2 port) WAN daughter card Hardware revision 1.0 Board revision B0 Serial number 30223169 Part number 800-06724-02
Test history 0x0 RMA number 00-00-00
Connector type PCI
EEPROM format version 1
EEPROM contents (hex):
0x20: 01 30 01 00 01 CD 2B 41 50 1A 44 02 00 00 00 00
0x30: 58 00 00 00 02 10 30 00 FF FF FF FF FF FF FF FF
Jalali
Goutam Sanyal Thu, 04/10/2008 - 22:22
  • Silver, 250 points or more
Jalali, can try the following
conf t
#card type e1
then you can check "sh run"
Thanks Goutam
pls rate if it helps you!!!
ahmedjalali Thu, 04/10/2008 - 22:36
Hi Goutam,
Thanks for your reply, I'm not seeing " card type" in my IOS 12.2.
Jalali
ahmedjalali Thu, 04/10/2008 - 22:51
I'm not seeing "card type" command in my IOS. IOS version is :
ROM: System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
I believe this IOS is compatible with VWIC-2MFT-G703.
Jalali
Goutam Sanyal Thu, 04/10/2008 - 23:24
Jalali, After "sh run" is the "card type e1" is reflecting? Goutam
rgodden Fri, 04/11/2008 - 00:52
  • Bronze, 100 points or more
the wic g703 can only be an e1 card , hence no card type command , you are mixxing it up with the e1/t1 vwic in which you have to tell it what card it is.
Try controller e1 slot number
timeslots etc
ahmedjalali Fri, 04/11/2008 - 01:08
No, nothing is reflecting in sh run. Although it is showing in show diag command.
Umair
Goutam Sanyal Fri, 04/11/2008 - 01:32
Umair, as per cisco, the supported platform and minimum IOS requirment for 38xx series 12.3(11)T, 28xx series is 12.3(8)T4, 1841 series 12.3(8)T4 check your IOS ver.
Hughes, you are right. Thanks
Goutam
ahmedjalali Fri, 04/11/2008 - 02:38
Dear Goutam,
Card is installed in Cisco 3745 with IOS version Version 12.3(8)T, and its meeting the minimum IOS requirement.
Below is the partial output of "sh version".
Cisco IOS Software, 3700 Software (C3745-ADVIPSERVICESK9-M), Version 12.3(8)T, RELEASE SOFTWARE (fc2)
Jalali
ahmedjalali Fri, 04/11/2008 - 04:03
Goutam,
Sorry, I mixed this with other router, IOS running is 12.2.
But as far as i think 12.3 is minimum requirement for 38xx router. I've 37xx router and 12.2 is minmimum IOS requirement for 37xx.
http://www.cisco.com/en/US/prod/collateral/routers/ps274/product_data_sheet09186a0080091b9c_ps259_Products_Data_Sheet.html
Jalali
