xlate log
Apr 11th, 2008
I have PIX 525 v.6.3. I configured global ip pool for my customers for internet connection. Each customer (company) has unique private ip (configured on the outside int of their CPE). I want to take the xlate log from the PIX at each moment everyday. Is there a way to do this (configuration or other means)?
srue Fri, 04/11/2008 - 04:41
  • Blue, 1500 points or more
are you wanting a snapshot of their translations?
You could set up logging for this, and then log it to a syslog server. you can change the log level of the messages you want.
or you could write a script that could do this. Perl works well for this sort of thing.
mulugetash Sat, 04/12/2008 - 00:36
as to the logging option to a log server, which ID (and level) is for xlate, so that I can use th cmd:
logging message [ID] level [level]
ofcourse the script option is pretty good.
