ezvpn + split tunneling -> broken nat
Apr 11th, 2008
Hello, all!
I set up ezvpn connection between pix (fos 7.0(6)) and cisco 831 (ios 12.4(18a)). Client is in network extension mode. PC behind 831 can access head office without problems. It's OK.
Than I needed to access from remote office Internet and I set up split tunneling. With it I encrypt only tunnel specified networks. At the same time I discovered that c831 began to create NAT rules which were not compatible with my wishes. How can I switch this irritating thing off? Is it possible or not?
With best regards,
Maxim
whjvdam1 Thu, 04/17/2008 - 10:22
Did you enable NEM on the pix? The default for NEM is off.
You can enable it with:
hostname(config)# group-policy FirstGroup attributes
hostname(config-group-policy)# nem enable
Wouter
