VIC 4FXS/DID problem
Apr 11th, 2008
we have a cisco 2821 h323 voice gateway with an E1 interface, when we insert a new vic4fxs module the command related to the serial0/0/0:15 are not anymore accepted
router1(config)#interface Serial0/0/0:15
% Invalid input detected at '^' marker.
Router version: Version 12.4(13r)T
Any idea?
Thank you.
Overall Rating: 0 (2 ratings)
Paolo Bevilacqua Fri, 04/11/2008 - 01:55
Likely you don't have enough dsp for bot E1 and 4 fxs, that requires 34 channels and you might have a pvdm2-32 only.
As a temporary workaround you can reduce the number of timeslots in pri-group.
acleri Fri, 04/11/2008 - 02:14
The E1 use 30 or 32 channels?
In case are 30 if I use VIC2-2FXS would be accepted?
Paolo Bevilacqua Fri, 04/11/2008 - 09:52
30 channels, but you can reduce this number to 28 with pri-group command under controller E1, and nothing bad will happen.
