Inter Control Communication Protocol and IEC 60870-5-104 DNP over TCP-IP on
Apr 11th, 2008
Dear All,
I needs a Router and a Firewall which supports Inter Control Communication Protocol and IEC 60870-5-104 DNP over TCP-IP.
We found a Network Design Presentation in the below CEC link however it does not specified the router model number that is being used in the presentation.
http://wwwin.cisco.com/pcgi-bin/search/intranet/search_redirect.cgi?query=IEC+60870-5-104&query_string=sitesearch_title%3Dthe%2520Intranet%26restrict%3Dintranet-new
Please suggest a router and firewall which can support Inter Control Communication Protocol and IEC 60870-5-104 DNP over TCP-IP.
Thank you for he help in advance.
Abdul
Paolo Bevilacqua Sat, 04/12/2008 - 05:18
Hi, you've asked this question already, here's my answer again:
1st, the link that you posted is internal to cisco only, so nobody here can see what the presention says.
2nd, generally speaking, all cisco routers do the same thing because they run the same software. Exception is the large models an L3 switches.
3rd, seeing that you're a cisco employee, you should have many many resources before resotritn to ask on this forum, haven't you tried these already ?
