New LMS3 install - DFM stuck learning
Overall Rating: 5 (1 ratings)
David Stanford Fri, 04/11/2008 - 05:55
  • Cisco Employee,
What percentage are these devices stuck at in discovery? 10%, 40%..?
100% all devices are still in the learning status. I also noticed just now when clicking on DFM > Configuration > Polling and Thresholds > Polling Parameters I get an error:
Could not retrieve current data since the PTMServer process is down.
Please restart the process and perform this operation again.
However ptmserver is running... (Program started - No mgt msgs received) I've stopped and started it a few times, but i still get the same error.
David Stanford Fri, 04/11/2008 - 06:29
  • Cisco Employee,
I meant are the stuck at 10% learning, 40% learning? Not the quantity of devices stuck
andrzej.kolman Tue, 04/15/2008 - 04:21
There is another bug CSCsm04957.
Perhaps this one is what you are hitting if you have .Net Framework 2.0 SP1 or 3.0, please uninstall it.
-Andrzej
I'm working with a TAC engineer at the moment and at first she thought it was a DNS issue due to errors in PTMServer.log and DFMLogServer.
PTMServer.log:
14 Apr 2008|12:27:53.308|ERROR|PTM_Log|Thread-38|||.|PTInformer:publishPTMStarupMessage:PTA not available or not responding:com.cisco.nm.vhm.vpta.PTAException: com.cisco.nm.xms.ctm.common.CTMException: URN_NOT_FOUND : urn "VPTA" : Not found !!
DFMLogServer.log:
14/Apr/2008 15:34:32:471 ERROR ? ? - URN_NOT_FOUND : urn "VPTA" : Not found !!
however DNS was working fine so we dumped the DFM db's copied a new sm_sms.dll library to CSCOpx\objects\smarts\lib and started the services back up. So far (fingers crossed) DFM is behaving properly. DFM is now moving devices from learning to known and we're currently @ 40% complete. Also the configuration screens are no longer throwing error messages.
simon
