ASDM IP NAMES appearing in log instead of IP Addresses
Apr 11th, 2008
I'm rather new to Cisco security technology. I've configured a PIX 525 through the ASDM interface and its working fine. The only problem I've got is that the SYSLOG is not showing me the IP addresses but the IP Names I have created through ASDM. Is there any way to disable viewing of logical IP Names ? Filtering functions on the logs are not running properly now. Thank you!
cisco24x7 Fri, 04/11/2008 - 06:24
  • Silver, 250 points or more
It is very simple. Are you running SYSLOG
on Linux/Unix?
If you're running syslog on Linux, go into
the file /etc/sysconfig/syslog and modify the
following configurtion:
# Options to syslogd
# -m 0 disables 'MARK' messages.
# -r enables logging from remote machines
# -x disables DNS lookups on messages recieved with -r
# See syslogd(8) for more details
SYSLOGD_OPTIONS="-m 0 -r -x"
# Options to klogd
# -2 prints all kernel oops messages twice; once for klogd to decode, and
# once for processing with 'ksymoops'
# -x disables all klogd processing of oops messages entirely
# See klogd(8) for more details
KLOGD_OPTIONS="-x"
restart your syslog with "service syslog restart". Now you will see IP addresses:
Apr 11 12:22:30 192.168.0.3 2950292: .Apr 11 14:31:40: %SEC-6-IPACCESSLOGP: list 190 permitted udp 10.250.97.28(0) -> 192.168.0.2(0), 1 packet
Apr 11 12:22:31 192.168.0.3 2950293: .Apr 11 14:31:41: %SEC-6-IPACCESSLOGP: list 190 permitted udp 10.250.97.9(0) -> 128.18.100.39(0), 1 packet
Apr 11 12:22:33 192.168.0.3 2950294: .Apr 11 14:31:43: %SEC-6-IPACCESSLOGP: list black_hole permitted udp 10.7.32.1(67) -> 255.255.255.255(68), 1 packet
Easy right?
CCIE Security
joe.favia Mon, 04/14/2008 - 01:51
No, I'm using Cisco MARS. I don't want my PIX to reverse lookup the IP addresses whenever it logs (level=informational). The log does not contain DNS resolvable names, but the IP Names associated within the ASDM.
Thanks.
