Firmware uploads in CCM 6.0.1
Mojo1
Where do you upload firmware in CCM 6.0.1?
pklos
Level 4
Level 4
You upload/install *.cop.sgn files on OS Administration page.
regards,
PK
If you have the files on your desktop how do you upload them since it asks for a server and username/password?
I guess I can browse to the server and put them on the server desktop if I have to.
You need to have ftp/sftp server, you can download tiny and handy (no need to install, just launch file) from here: http://www.coreftp.com/server/
regards,
PK
you can refer to this guide:
Software Upgrades
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/5_1_1/iptpch7.html
You can use the Software Upgrades options to perform the following types of installations and upgrades:
•Install/Upgrade-Use this option to upgrade the application software, install Cisco Unified CallManager Locale Installers and dial plans, and upload and install device packs, phone firmware loads, and other COP files.
javalenc
if this helps, please rate
java
