voice translation-rules
Answered Question
hi guys
I have a problem in the configuration of the voices translation-rule
can someone help me?
my problem and that I have a line in entry (PRI) with did to two digit and internally I have three digit 5xx while the external number is actually 3989005xx to here nesun problem for the operation.
But I don't succeed in making to visualize the whole number in exit included theinside number
on the debug isdn is proposed the whole number, but I don't understand because is not visualized.
I have planned this configuration but not sò if it is correct
voice translation-rule 50
rule 1 / ^ \ (. * \) / / \1 / type unknown unknown
rule 2 / ^ \ (. * \) / /0\1 / type national national
rule 3 / ^ \ (. * \) / /00\1 / type international international
voice translation-rule 51
rule 1 / ^5 \ (.. \) / /3989005\1 /
voice incoming translation-profile
translate calling 50
voice translation-profile uscenti
translate calling 51
voice-port 0/0/0:15
translation-profile incoming entranti
local-alerting
cptone IT
bearer-cap Speech
dial-peer voice 20 potses
translation-profile outgoing uscenti
destination-pattern 0.T
port 0/0/0:15
dial-peer voice 10 potses
translation-profile incoming insert-zero
incoming called-number 3989005..
direct-inward-dial
no register e164
Correct Answer by Paolo Bevilacqua about 8 years 9 months ago
You have asked this question already, beside for many would be hard to understand "nesun problem" :)
Check that sometime TI doesn't allow outgoig DID and you have to request they do.
Overall Rating: 3 (1 ratings)
Correct Answer
Paolo Bevilacqua Fri, 04/11/2008 - 10:25
