Keepalive state
Apr 11th, 2008
I'd like to know if it is possible to keep a state in a scripted keepalive between each script execution. I guess it's probably possible thanks to a file but it's not very elegant solution.
Any idea?
Gilles Dufour Mon, 04/14/2008 - 07:33
  • Cisco Employee,
the only solution is a file indeed, but this is really not recommended as we have seen that such a script kills the flash disk much faster than usual resulting in disk failure causing more trouble than you would want.
Gilles.
David Coupez Mon, 04/14/2008 - 23:41
And is it possible to run a Keepalive without assigning it to a service. To explain my idea, I'd like to assign two KA to a service. Since its not possible I wanna script to check if both KA are up.
Thanks again,
David
Gilles Dufour Tue, 04/15/2008 - 03:27
  • Cisco Employee,
You can create multiple services for the same server, each one with a single keepalive and only use in your content the service with the keepalive that check the status of the other services.
Gilles.
David Coupez Tue, 04/15/2008 - 04:33
Okay, that's what I've planned to do.
Thanks for your time.
David
