Sup engine MSFC card
Apr 11th, 2008
Wanna ask that in 6509e chasis, install with the 2 unit sup2 module which do as redundancy.
So with the "Sh Module" command in CAT OS, will it show 2 unit of MSFC card?
-Gilbert
gilbertthor Fri, 04/11/2008 - 08:15
hi,
So if i show module but not able to see the module 16 means the MSFC card might be failure right?
by the way , thks for u reply.
-Gilbert
