cannot access LAN from DMZ and vice versa
Answered Question
Apr 11th, 2008
I have PIX 515E, version 6.1(4) and I'd like to allow all traffic from DMZ to LAN and vice versa but can't get it to work.
I do have nat, global, and acls configured but I must be doing something wrong.
And also for some reason, the machines inside the inside interface cannot go out to the internet (can't even ping anything outside) but the machines behind the DMZ can.
Any suggestions would be appricated!
Full running config:
PIX Version 6.1(4)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz security40
enable password encrypted
passwd encrypted
hostname pix
domain-name pix.loc
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list 102 permit ip 10.10.31.0 255.255.255.0 10.10.16.0 255.255.255.0
access-list 103 permit ip 10.10.16.0 255.255.255.0 10.10.61.0 255.255.255.0
pager lines 24
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
mtu outside 1500
mtu inside 1500
mtu dmz 1500
ip address outside x.x.x.x 255.255.255.0
ip address inside 10.10.16.1 255.255.255.0
ip address dmz 10.10.31.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 10.10.16.0 255.255.255.0 0 0
nat (dmz) 1 10.10.31.0 255.255.255.0 0 0
static (inside,dmz) 10.10.16.0 10.10.16.0 netmask 255.255.255.0 0 0
access-group 102 in interface inside
access-group 103 in interface dmz
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
no sysopt route dnat
telnet timeout 5
Correct Answer by acomiskey about 8 years 11 months ago
Remember, there is an explicit deny statement at the end of your acl's. So they really look like this...
access-list 102 deny ip any any
access-list 103 deny ip any any
Therefore I don't see how even the dmz would be getting to the internet. This statement should take care of communication between the two interfaces.
edit: Good catch srue.
Correct Answer by srue about 8 years 11 months ago
no access-group 102 in interface inside
no access-group 103 in interface dmz
access-group 103 in interface inside
access-group 102 in interface dmz
btw, doing this negates any security provided by your dmz.
Overall Rating: 5 (2 ratings)
Correct Answer
srue Fri, 04/11/2008 - 09:28
  • Blue, 1500 points or more
Correct Answer
acomiskey Fri, 04/11/2008 - 09:30
  • Green, 3000 points or more
pixnewb11 Wed, 04/16/2008 - 16:18
Thanks guys, I finally got around to looking at this again.
So I've made the changes that both of you suggested and it's working now.
ACLS:
access-list 102 permit ip 10.10.31.0 255.255.255.0 10.10.16.0 255.255.255.0 (hit
access-list 102 permit ip 10.10.31.0 255.255.255.0 any
ACCESS-GROUPS
STATIC:
I've taken out the access-list 103 since the inside interface has access to dmz by default.
What does "static (inside,dmz) 10.10.16.0 10.10.16.0 netmask 255.255.255.0 0 0
" do?
Is it saying that the traffic (actual subnet is 10.10.31.0) from dmz entering the inside interface will be mapped to 10.10.16.0?
Then do the nodes from dmz appear as they're from 10.10.16.0 IP wise?
And how come I don't need to do one for static (dmz,inside)? I'm assuming it has to do with the interface's security level?
Thanks!
acomiskey Wed, 04/16/2008 - 16:56
You actually want to be more specific with your acl, otherwise you've defeated the purpose of a dmz.
access-list 102 permit tcp/udp 10.10.31.0 255.255.255.0 10.10.16.0 eq xxx
access-list 102 deny ip 10.10.31.0 255.255.255.0 10.10.16.0 255.255.255.0
"static (inside,dmz) 10.10.16.0 10.10.16.0 netmask 255.255.255.0" will exempt your inside subnet from nat so they will appear on the dmz as their real address.
