75975 Background Image.
We have recently installed CCM 6.1(1) with 7975 color phones. We are trying to display a custom image on the phones and are having no luck. Through the call manager OS Administration page I have uploaded the .png files for the image and the thumbnail to the tftp server. I also uploaded the List.xml file to the Desktops/320x212x16 directory. I have stopped and started the tftp service, dissabled and re-enabled the Caching of Constant and Bin Files at Startup and rebooted the server. When I try to select a new background image I get a "Selections Unavailable" message on the phone. Any help is appreciated.
Jason
rob.huffman Fri, 04/11/2008 - 11:37
Hi Jason,
I think you need Desktops/320x216x16 (note 216 not 212)
The List.xml file defines an XML object that contains a list of background images. The List.xml file is stored in the following subdirectory on the TFTP server:
/Desktops/320x216x16
List.xml Example
FTP:Desktops/320x216x16/TN-Fountain.png"
URL="TFTP:Desktops/320x216x16/Fountain.png"/>
FTP:Desktops/320x216x16/TN-FullMoon.png"
URL="TFTP:Desktops/320x216x16/FullMoon.png"/>
From this good 7975 doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7975g/6_1/english/administration/guide/7975cst.html#wp1088046
Hope this helps!
Rob
aramos17428 Fri, 05/30/2008 - 00:10
Jason,
Did you get this working?
I'm having the same issue with CM 6.1.1 and 7970s
I followed Rob's instructions but still no luck keep getting the "selections Unavailable" when trying to select a background
Armando
thisisshanky Fri, 05/30/2008 - 11:51
You should restart the TFTP services once you upload the files. I have never got this working on a 7975 with out restarting the TFTP service after you upload the file.
aramos17428 Wed, 06/04/2008 - 19:49
Thanks Guys
However, I did restarted the tftp service after I uploaded the pictures to the TFTP directory
Desktops/320x216x16
I know the pictures are good since I backed them up before I did the CM upgrade from 4.1.3 to 6.1.1
Am I missing something?
Armando
Jaime Valencia Thu, 06/05/2008 - 04:02
Where is the list.xml?
it should be under:
/Desktops/320x212x12
javalenc
if this helps, please rate
Jaime Valencia Thu, 06/05/2008 - 07:52
well, i'm really not sure at this point which model we're talking about, the original post was for 7975s, but then aramos17428 posted he was having issues with CM 6.1.1 and 7970s
so indeed the image size changes but i guess we'll have to wait to see which phone model we're talking at this point
javalenc
