Network Camera Access Via Internet
Apr 11th, 2008
I have a d-link network camara. I connect it to my FE04 router (1811). How do I setup to have my people access to this camera by having them to enter ip address in internet with userid and password?
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Fri, 04/11/2008 - 12:21
  • Hall of Fame,
    Founding Member
If it works as web server, configure a static nat translation:
ip nat inside source static tcp 80 interface 800
I've put 800 as external port address so you can use 80 for router management if you want.
Then you can configure dynamic dns in the router so you always reach it.
hoadotnguyen Fri, 04/11/2008 - 12:22
how do I setup to have outside user enter userid and password before they can see my net camera?
Paolo Bevilacqua Fri, 04/11/2008 - 13:03
  • Hall of Fame,
    Founding Member
Sorry, that is not supported. You have to rely on some PC software for that.
hoadotnguyen Thu, 04/17/2008 - 10:24
I got it to work, but user from outside and they want access to my camera, they have to enter as below: http://x.x.x.x:800
Two questions please:
Is the way I can convert my ip to other DNS?
How do I turn on firewall prevent from other access to my network?
