Richard Burts Fri, 04/11/2008 - 12:14
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Sabir
The easy way to see the helper address is to execute the command show ip interface
There is a line in the output that will clearly identify the helper address if one is configured.
The alternative would be to look into the running config and look for ip helper-address commands.
Rick
