MGCP commands got erased
Apr 11th, 2008
Hi i have a callmanager 4.1 that has 2 fxs and 4 bri registered using MGCP. The problem is that the mgcp commands that associate this interfaces to the call agent got erased suddenly loosing connection qith the callmanager.
Do anyone had this problem before, thanks in advanced.
Pepe
Jaime Valencia Fri, 04/11/2008 - 20:22
  • Cisco Employee,
  • Hall of Fame,
    2011
by any chance did you erased the GW in CUCM and had configured the ccm-manager config??
was that the only part that was lost?
javalenc
if this helps, please rate
