how do you create an open ssid?
Apr 11th, 2008
I want to create an open ssid with no authentication. How can I do this? When I use "authentication open" and "guest mode" i pick up the network but it shows it as secure.
wiluszm Sat, 04/12/2008 - 11:57
  • Bronze, 100 points or more
I'm assuming this is a question about unified wireless (LWAPP)... sorry if I got it wrong. To make the SSID "open," set the Layer 2 security option under the created SSID as "None." This will leave the WLAN open with no encryption. Also make sure you're broadcasting the SSID (should be a check box under the WLAN). Hope this helps!
-Mike
http://cs-mars.blogspot.com
bcolvin Sat, 04/12/2008 - 12:27
Sounds like you have some old Security settings in there.
Step 1. With the WEB interface select System software, Config, and reset to defaults except IP address.
Step 2. express setup set your SSID; you AP should be open to ALL.
Step 3. chose guest mode again to broadcat SSID
Enjoy
Bill
bcolvin Wed, 04/23/2008 - 14:14
Due to the number of inter related settings in the AP I strongly suggest you use the GUI for the initial setup. once you have the AP configured you can display the saved/runnig config and see the command line. you cna then disable the GUI with the no HTTP server command if you need to for security reasons.
the other method to reset the AP is to hold down the mode button and then apply power and wait for the light to turn yellow and then release the mode button your AP will then be reset to default config.
Bill
MZydorczyk2 Thu, 04/24/2008 - 07:58
i have enabled the http server and it already had an ip address but when I go the the address in my browser it doesnt show anything.
bcolvin Thu, 04/24/2008 - 08:11
Can you post your sanitized config
Bill
MZydorczyk2 Thu, 04/24/2008 - 08:24
version 12.2
no service pad
service password-encryption
hostname extra_ap
enable secret
ip subnet-zero
no ip domain lookup
ip domain name ---
ip name-server ---
aaa new-model
aaa group server radius rad_eap
server ---- auth-port 1812 acct-port 1813
aaa group server radius rad_mac
server --- auth-port 1812 acct-port 1813
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server radius rad_pimp
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods group rad_mac
aaa authorization exec default local
aaa authorization ipmobile default group rad_pmip
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 holdoff-time 600
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip wep128
broadcast-key change 60
ssid ecc
authentication open eap eap_methods
authentication network-eap eap_methods mac-address mac_methods
authentication key-management wpa
accounting acct_methods
ssid test
authentication open
guest-mode
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
rts threshold 2312
channel 2437
station-role root fallback shutdown
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.1
no ip route-cache
shutdown
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address ---
no ip route-cache
ip default-gateway ----
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag/ivory/1100
ip radius source-interface BVI1
logging trap debugging
logging facility local2
logging ----
access-list 2 permit ---- log
access-list 3 deny any log
snmp-server group eccread v3 auth read internetview access 2
snmp-server group eccwrite v3 auth write internetview access 2
snmp-server view internetview internet included
snmp-server community readonly RO 2
snmp-server community readwrite RW 2
snmp-server community public RO 3
snmp-server community private RW 3
snmp-server location NI1013
snmp-server contact ECC
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps entity
snmp-server enable traps disassociate
snmp-server enable traps authenticate-fail
snmp-server enable traps config
snmp-server enable traps syslog
snmp-server enable traps aaa_server
snmp-server enable traps rogue-ap
snmp-server host ---- version 2c aptrap
radius-server host ------ auth-port 1812 acct-port 1813 key 7 ---
radius-server attribute 32 include-in-access-req format %h
radius-server authorization permit missing Service-Type
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 0 4
transport input ssh
line vty 5 15
transport input ssh
ntp clock-period 2860636
ntp server -----
end
MZydorczyk2 Fri, 04/25/2008 - 07:23
What I am trying to do is create an SSID with complete open access and another SSID that goes to a radius (which is already set up on the access points). I want both of these ssid's to be on the same access point. Is it possible to do this? I was told you have to have 2 separate dot11 interfaces but this access point only has one dot11 interface, as you can see in the above config.
Trending Topics - Security & Network
