Paolo Bevilacqua Fri, 04/11/2008 - 15:57
On the cme, Configure voice register global, dn and pool. Under pool, mac address doesn't matter, configure username same as number, codec g711u.
On the phone via web, configure proxy and registrar with the cme address, username and password.
These are the minimum steps.
filiberto.aguirre Tue, 05/20/2008 - 14:04
hi Craig,
I checked the guide you recommended but I could not register linksys's SIP phone.
some commands were not valid, I have CME 4.0
e.g. name, label
do you have an example of how did you configure one of your linksys phone.
regards
Paolo Bevilacqua Tue, 05/20/2008 - 14:08
First, configure mode cme under voice register global. There are many posts here regarding that, use the search function.
