Multicast router passing traffic when OIL = NULL
Apr 11th, 2008
R4
R1 R3
R2 R5
--------- <----- Ethernet
R6
All interfaces have pim sparse-dense mode enabled.
All routers have R4 configured as static RP (4.4.4.4).
R6 has a igmp join-group 239.0.0.6 on its ethernet interface.
After R5 sends a ping to 239.0.0.6, R6 does reply.
However this is how the mroute tables look on R5 and R2:
R5#show ip mroute
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
L - Local, P - Pruned, R - RP-bit set, F - Register flag,
T - SPT-bit set, J - Join SPT, M - MSDP created entry,
X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
U - URD, I - Received Source Specific Host Report,
Z - Multicast Tunnel, z - MDT-data group sender,
Y - Joined MDT-data group, y - Sending to MDT-data group
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 239.0.0.6), 00:35:13/stopped, RP 4.4.4.4, flags: SP
Incoming interface: Serial1/0, RPF nbr 172.12.35.3
Outgoing interface list: Null
(172.12.25.5, 239.0.0.6), 00:00:14/00:02:51, flags: PT
Incoming interface: FastEthernet0/0, RPF nbr 0.0.0.0
(*, 224.0.1.40), 00:49:30/00:02:16, RP 4.4.4.4, flags: SJPL
R2#show ip mroute
(*, 239.0.0.6), 00:35:16/stopped, RP 4.4.4.4, flags: SP
Incoming interface: Serial1/0, RPF nbr 172.12.12.1
(172.12.25.5, 239.0.0.6), 00:00:17/00:02:44, flags: PT
(*, 224.0.1.40), 00:51:48/00:02:14, RP 4.4.4.4, flags: SJPCL
How can R6 get the ping request when all the outgoing interface lists towards R6 are NULL?
-B
Overall Rating: 4 (1 ratings)
dodgerfan78 Fri, 04/11/2008 - 16:47
sorry for the bad drawing.
This is how it is
R4 - R1 - R2--|
R4 - R3 - R5--|-- R6
R6, R2 and R5 are on the same LAN
all other links are p2p.
R1 is also connected to R3.
R5 has to send the pim register up to R4, then R4 sends the traffic right back...
Harold Ritter Sat, 04/12/2008 - 05:25
Bryan,
This behavior is due to the fact that R5 receives the IGMP report message from R6 and therefore responds directly. Try issuing the ping from r3 instead and you should see a different behavior.
dodgerfan78 Mon, 04/14/2008 - 16:08
Thanks. I do see different and interesting behavior. I am sure I will have many more questions :)
