04-11-2008 06:59 PM - edited 03-03-2019 09:31 PM
How do I determine the serial# for a PA-4T adapter and once I located the sn, how do I go about determining the device's authenticity? Does Cisco keep a database of all serial numbers that I could check against?
Thanks for any help you could provide.
Solved! Go to Solution.
04-11-2008 08:29 PM
Should be an 8 digits number without dashes.
04-11-2008 07:56 PM
You can see serial numbers with eithe r"show diag" or physical inspection.
Cisco has the database of all units produced, but you must do this request through eiter your sales or support team.
04-11-2008 08:20 PM
Thanks for responding...I have the card in front of me but there are different numbers all over the card and I can't tell which one is the SN. I can't do a "show diag" because I don't have access to telnet nor console in. Which number on the adapter is the SN?
04-11-2008 08:29 PM
