paolo bevilacqua Fri, 04/11/2008 - 20:42
  • Hall of Fame,
    Founding Member
Hi, you had asked this question already, the answer is the same, disable dynamic arp under interface, and configure static arp entries in global config.
tarun.shee Mon, 04/14/2008 - 02:19
Sir,
according to your instruction, I have configrue. But not getting result. Configuration as follows-
interface GigabitEthernet2/0/4
description "Link To 55222"
switchport access vlan 7
switchport mode access
duplex half
speed 10
no arp arpa
arp 10.230.8.10 0017.5982.b010 ARPA
Tarun
paolo bevilacqua Mon, 04/14/2008 - 02:44
  • Hall of Fame,
    Founding Member
This config goes on the router. It will not work on a switch unless it is a L3 switch and you enable routing.
tarun.shee Mon, 04/14/2008 - 19:32
sir,
This is Cisco 3750 switch. Am I need to changed the configuration.
Tarun
