MAC ACLs on load balancer
Apr 11th, 2008
Hi to all,
I wanted to know if Cisco has built load balancers which support MAC ACLs like on its switches. I know that some Cisco Load Balancers support standard IP and Named IP ACLs. But what abt standard MAC and Named MAC ACLs?
Thx in advance..
Warm regards,
Visham
didyap Thu, 04/17/2008 - 13:44
  • Silver, 250 points or more
You can configure the MAC ACL with the Cisco Access Point. To create the filters with the
Cisco Access Point CLI following the steps :
1) Log in to the AP through the CLI.
2) Issue the config terminal command to enter global configuration mode on the AP:
AP#configure terminal
3) Enter these commands to create the ACL:
Access-list 700 permit XXXX.XXXX.XXXX 0000.0000.0000
Access-list 700 deny 0000.0000.0000 ffff.ffff.ffff
!--- This command line has to be the last one, for every new MAC applied.
4) Apply this ACL to the radio interface:
AP#interface Dot11Radio 0
5) Issue the l2-filter bridge-group-acl end command.
6) Issue the write command.
I hope it will help you.
