config interface ip via snmp
arikgelman
Level 4
Level 4
I am trying to change an ip address of interface on a router via snmp but i can't find any documentation about how to do it.
I also found and snmp table:
ciiIPAddressConfiguration
1.3.6.1.4.1.9.9.309.1.1
but i couldn't understand how to change a value on this table, and there is no values at all when i am trying to read it.
Can anyone help me?
thanks in advance.
Joe Clarke
This can't be done directly. You will need to create a small config file containing the modification you would like to make, then push that config file to the device via a protocol like TFTP. The TFTP fetch can be triggered via SNMP, however. See this tech tip for more details:
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_configuration_example09186a0080094aa6.shtml
Your configuration snippet will look something like:
interface FastEthernet0/0
ip address 10.1.1.1 255.255.255.0
end
Joe Clarke
end
