24 port POE Switch w/100fx uplink?
Apr 12th, 2008
I have several buildings on our campus that we are looking at installing ip phones in. The problem is the existing fiber to these buildings is only Multimode and is over 1000 feet which is too far for Gigabit over multimode. Are there any 24 port POE 802.1af switches available that have 100fx uplinks?
Overall Rating: 5 (3 ratings)
mattcalderon Sat, 04/12/2008 - 11:15
True Paulo, I did not consider the 29xx series. But you are right when it comes to economics, the 2960s are a much cheaper switch than the 37xx series.
mattcalderon Sat, 04/12/2008 - 11:24
After taking a closer look and paulo please correct me if i am wrong but the Cisco Catalyst 2960-24PC-L is the only switch that supports POE on all 24 switch-ports but I don't see that model in the compatibility matrix for the 100FX SFPs.
Paolo Bevilacqua Sat, 04/12/2008 - 11:34
I kind of knew that objection would have been raised by an alert reader :)
Worry not, the compatibility table just predates the poe switch. The SFP support is common to all models.
mattcalderon Sat, 04/12/2008 - 11:39
Thanks for the clear up P! Thats why you are one of the top experts....Another five points!!!
NPT_2 Sat, 04/12/2008 - 17:21
ThanksPalo for the great suggestion. 5 points headed your way.
