Telnet into ASA 5510 - no longer can do this
Apr 12th, 2008
I have a ASA 5510 firewall Latest versions of
IOS and ASDM.
I am using hyperTerminal or Telnet and something has changed
on my firewall configuration.
I was able to get a full view of my ASA configuration
Top to bottom using these utilities - but no longer.
What changed and how can I fix it.
Overall Rating: 5 (1 ratings)
JORGE RODRIGUEZ Sun, 04/13/2008 - 06:49
console into the 5510 and take note of telnet access, it is very possible something changed on the hosts that used to access the asa like the IP address.
e.i, say you are accessing asa from inside hots ip 192.168.1.20
asa(config)#telnet 192.168.1.20 255.255.255.255 inside
or if you want to avoid being so granular in which hosts on a given interface can telnet to asa you can simply allow any.
e.i
asa(config)#telnet 0.0.0.0 0.0.0.0
Rgds
Jorge
