Under attack! Need help with IPS
Apr 13th, 2008
Some guy is coming to our site and demanding a payoff or he will DDoS us. We didn't pay him and he did what he said he was going to do. I expect another attack at any time.
The flood was only 10Mb, but our cisco was not tuned as good as it could be. I think with the better config, I will be able to simply absorb it using TCP intercept and IPS.
I found a good attack signature that I would like to use IPS for, to keep the packet from the web servers completely.
I am trying to setup the cisco IPS on the front facing interface of a
3845 router. Every time I enable the IPS, no packets are allowed to
pass through the router. w/out IPS, everything works fine (except
there is no IPS). The moment I enable it, nothing can get through.
I have:
ip ips sdf location flash://sdmips.sdf
ip ips sdf location flash://256MB.sdf autosave
ip ips name sdm_ips_rule_IPS list IPS
interface GigabitEthernet0/0
ip address <--- edited for the example
ip access-group gigabitethernet0/0_in in
ip access-group sdm_gigabitethernet0/0_out out
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip ips sdm_ips_rule_IPS in
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
media-type sfp
no mop enabled
crypto map SDM_CMAP_1
crypto ipsec df-bit clear
ip access-list extended IPS
remark SDM_ACL Category=1
permit tcp any host eq www <--- just a test host on our
network. www packets are being blocked
If I change the ACL to deny, then everything passes just fine. It's
only when I change the ACL to send packets through the IPS that it
stops cold.
Does anyone have an idea what the problem might be?
thank you,
Syed Fayum
Overall Rating: 4 (1 ratings)
mhellman Mon, 04/14/2008 - 06:30
if you are legitimately being blackmailed, you should probably get the authorities involved. Here in the US, that would be the FBI. Hopefully you have an equivalent. The chances that an IPS at the last mile is going to be effective against a botnet DDoS seems pretty unlikely. I would recommend working with your Internet Service Provider to see what help they can offer.
rhermes Mon, 04/14/2008 - 07:28
mhellman is correct, you can not protect yourself against a DDoS attack from your end. As long as the attacker has more bandwidth of attack traffic than you have in internet access, your internet access will be filled and rendered useless. Some ISP's offer DDoS scrubbing services. If your attacker is only using a few hosts your ISP may filter their IPs.
