VPN Client - Failing to conect to ASA 5505
danielstaunton
I get these following messages in my syslog,when I try to connect to my asa using the cisco vpn client.
IP = remoteip, Received encrypted packet with no matching SA, dropping
Group = RASVPN, Username = administrator, IP = remoteip, Session disconnected. Session Type: IPSec, Duration: 0h:00m:00s, Bytes xmt: 0, Bytes rcv: 0, Reason: crypto map policy not found
Group = RASVPN, Username = administrator, IP = remoteip, Removing peer from correlator table failed, no match!
Group = RASVPN, Username = administrator, IP = remoteip,QM FSM error (P2 struct &0x3c9f388, mess id 0x2a0ab40b)!Group = RASVPN, Username = administrator, IP = remoteip, Rejecting IPSec tunnel: no matching crypto map entry for remote proxy 192.168.100.1/255.255.255.255/0/0 local proxy 0.0.0.0/0.0.0.0/0/0 on interface outside
Group = RASVPN, Username = administrator, IP = remoteIP, PHASE 1 COMPLETED
Group = RASVPN, Username = administrator, IP = remoteip, Assigned private IP address 192.168.100.1 to remote user
Group = RASVPN, Username = administrator, IP = remoteip, Client Type: WinNT Client Application Version: 5.0.01.0600
Group = RASVPN, Username = administrator, IP = remoteip, Received unknown transaction mode attribute: 28684
Group = RASVPN, Username = administrator, IP = remoteip, Received unsupported transaction mode attribute:
It has been working for a while, but it stopped when I added a new site to site tunnel.
can anyone please help?
ANGUEL STEFANOV
make sure that the RA dynamic policy is mapped to your site-to-site static policy
